Hi All
Is there a way to reduce the entities in this file ? at the moment it has 1078 lines..
Is it possible to convert a bunch of lines into splines and then explode to arcs?
Any help will be appreciated..
Cheers
John Hyslop
PS I want to lasercut this..
[ Satisfied with Solution ] Convert Lots of Lines to Arcs
- Premier Member
IF IT IS TO BE IT IS UP TO ME [ Ten most powerful 2 letter words ]
- Husky
- Moderator/Drawing Help/Testing
Re: Convert Lots of Lines to Arcs
Sure - but you will loose details ...John Hyslop wrote: ↑Wed Apr 27, 2022 1:33 amIs there a way to reduce the entities in this file ? at the moment it has 1078 lines..
No, not that I know of ...John Hyslop wrote: ↑Wed Apr 27, 2022 1:33 amIs it possible to convert a bunch of lines into splines and then explode to arcs?
What about a polyline with reduced segments?
BTW: Tasmania would be much less work ....
- Premier Member
Hi Husky
I tried an AutoCAD Lisp file to convert polyline to spline but when I exploded it in Qcad I finished up with twice as many entities
I don't mind loosing some..
Cheers
John Hyslop
Would you mind showing an example how to do this pleaseSure - but you will loose details ...
Cheers
John Hyslop
- Husky
Select the whole contour,John Hyslop wrote: ↑Wed Apr 27, 2022 3:04 amWould you mind showing an example how to do this please
launch "Polyline from Selection" (OC),
select the polyline,
launch "Simplify (OS),
"play" with the tolerance in the option bar to see what works best for you - I assume something between 0.1 - 0.5. The Tolerance bar has a Node indicator and a life preview is provided in the drawing too ...
- Premier Member
Thanks Husky
That's Perfect Got Rid of All The Small Lines...
Cheers
John Hyslop
Cheers
John Hyslop
- Husky
Re: [ Satisfied with Solution ] Convert Lots of Lines to Arcs
You're quite welcome!
Cheers.
Cheers.
