Editing dimension text and format
- Registered Member
My drawing has items that are feet long. How do I edit dimensioning to be able to see it without zooming in on it.
- Husky
- Moderator/Drawing Help/Testing
Re: Editing dimension text and format
You can change the dim label text height for the actual drawing below Menu / Edit / Drawing Preferences / Dimension Settings.
Alternative you can use the Info tools for a quick check on dimensions.
Note: For printing most likely you have to change the dim text height regarding to the print scale.
