Snowflakes
About the creation of DXF / DWG part library items.
Clive
Moderator
Snowflakes
Post by Clive » Wed Dec 11, 2013 12:18 pm
Hi everyone
Here's some snowflakes that you can laser cut or just print out and intersect them together :)
* You may need to modify the slot dimensions to suit the material you are using, in the file they are at 3mm wide to suit the acrylic I used.
Snowflakes, round and sharp.dxf
(214.8 KiB) Downloaded 1939 times
Have fun :wink:
For the best support please state your operating system, QCAD version and add any supporting DXF/DWG files, screenshots etc...
Return to “Creating DXF/DWG items”
