Table Saw Push Stick ...
About the creation of DXF / DWG part library items.
Husky
Moderator/Drawing Help/Testing
Post by Husky » Sat Oct 20, 2012 12:08 am
I was in need of a simple Table Saw Push Stick .... maybe you too :wink:
Free to use for all QCad User!!!
Husky_Table Saw Push Stick Print View.png (4.48 KiB) Viewed 95727 times
Husky_Table Saw Push Stick QCad Design.png (9.83 KiB) Viewed 95727 times
Husky_Table Saw Push Stick.dxf
(90.27 KiB) Downloaded 2835 times
Have fun!!!
Clive
Moderator
Re: Table Saw Push Stick ...
Post by Clive » Mon Oct 22, 2012 8:46 pm
Husky
Thanks for this, I re-scaled your little push stick, changed everything to a continuous polyline and changed the line-weight to 0.00mm and cut out on the laser cutter.
Now its perfect for using with the little bandsaw for small jobs, I`m sure it will be the first of many!
See below - photo`s of the ' Husky' push stick MK 1 :wink:
push stick 2.jpg (109.34 KiB) Viewed 95373 times
push stick 1.jpg (107.62 KiB) Viewed 95373 times
Husky
Post by Husky » Mon Oct 22, 2012 10:27 pm
Nice!!! Thanks for the feedback! I like to see "Finger saver" around the world :lol:
Return to “Creating DXF/DWG items”
