Always have to login every visit here...!
- Registered Member
What's wrong with the forum software that forces me to login every time I come here? Even if only 2 minutes after my last visit. I'm using Firefox and phpBB seems to work for other forums but this one is annoying as heck as every visit I have to re-login before doing anything.
- andrew
- Site Admin
Re: Always have to login every visit here...!
I suspect that this might be a domain name issue. You probably logged in over qcad.org but the login cookie is always set for ribbonsoft.com by phpBB. I've fixed the problem by redirecting qcad.org to ribbonsoft.com instead of sharing the contents. Thanks for the report.
Our web site / phpBB 3 installation is only a few weeks old, so there might still be some other hick-ups.
- Registered Member
Thank You.
Just tested that here and it seems to be correct. Using the ribbonsoft domain I am able to leave and come back and have it keep my login status.
- Registered Member
try to clear your cache or check your tools/add ons.
