Screen Cursor Size
colpat47
- Newbie Member
Screen Cursor Size
Hi,
I have just upgraded my operating system from POP_OS 22.04 to POP_OS 24.04 LTS Cosmic
Since re-installing QCAD I cannot get the cursor to the right size - if I got outside the QCAD display the cursor drops to the right size.
My external screen is 23.4" @ 1920 x 1080, 60Hz & scale 100%.
I have screen pics of cursor. In QCAD quite large, move onto open app and cursor drops to proper size.
Does anyone know how to change the cursor size? I have looked in App Preferences - Graphics View - Appearance but can't find anything to change.
- Attachments
- Cursor Small Other App..jpg (829.98 KiB) Viewed 4452 times
- Cursor Large in QCAD.jpg (837.01 KiB) Viewed 4452 times
- andrew
- Site Admin
colpat47
- Newbie Member
Re: Screen Cursor Size
Recommended link option does not work. I have it set to system cursor.
- Attachments
- Cursor Small.jpg (252.63 KiB) Viewed 4396 times
- Cursor Large.jpg (232.63 KiB) Viewed 4396 times
- andrew
- Site Admin
Thanks for the feedback. Unfortunately, this means we cannot solve this problem from our end as this would be a system setting, feature or problem as the window system is controlling the cursor size.
Can you please indicate your exact QCAD version and if you are using Wayland or X11?
colpat47
- Newbie Member
Please see attached screen shot
- Attachments
- Screenshot_2025-10-30_14-41-11.png (335.85 KiB) Viewed 4078 times
- andrew
- Site Admin
If you are willing to invest some time in resolving the issue, you might want to try the 3.32.3.1 development snapshot release which is Qt 6 based. You can download it from your download link under "QCAD Professional Snapshots".
If that does not solve the issue, try to change "-platform xcb" to "-platform wayland" in the "qcad" launch script. That might make a difference as well.
colpat47
- Newbie Member
Many, many thanks Andrew, I will try your suggestions and let you know.
colpat47
- Newbie Member
I downloaded and installed 3.32.3.1 but couldn't get it to open by double clicking on the desktop icon. I changed -platform xcb to platform wayland in the qcad file but it still wouldn't open.
I tried changing the platform xcb to platform wayland in the qcad file for version 3.32.4.0. But by doing that, that version then wouldn't work either. Changed the platform back to wayland and system still wouldn't work. Had to delete system and re-install.
Do you think it would have anything to do with the new Cosmic desktop environment?
- andrew
- Site Admin
Unfortunately, it could have anything to do with Qt, your window manager, Wayland, your external monitor, Cosmic or any combination of any of those.
Disconnecting the external monitor seems like an easy way to confirm or rule out the monitor as a potential cause, assuming that you are on a laptop with an external monitor attached.
Also: did you try to disable system mouse cursors and use the Qt mouse cursors instead?
colpat47
- Newbie Member
Have tried on laptop with same results.
How do you disable system mouse cursor and use Qt mouse cursor?
