How to get ByLayer Dim text color
Use this forum to ask questions about how to do things in QCAD.
Post by CVH » Mon May 10, 2021 1:05 pm
QCAD Professional
Win 7, 32 bit, winUpdater
Version: 3.26.2.0 (3.26.2)
Internet: QCAD.org
Build Date: Apr 13 2021
Revision: 57092ea
Qt Version: 5.13.2
Architecture: i386
Compiler: Unknown
All,
After update to 3.26.2
How can I get the Dimension text back to byLayer?
Black DIM text.png (74.52 KiB) Viewed 15110 times
DimTextColorPersistent.dxf
(102.88 KiB) Downloaded 904 times
Thanks,
petevick
Re: How to get ByLayer Dim text color
Post by petevick » Mon May 10, 2021 4:11 pm
In your dxf I just opened you have the dimension text, or label colour set to BYLAYER, ie all elements in the four dimensions display the BYLAYER colour.
Pete Vickerstaff
Linux Mint 21.3 Cinnamon, Qcad Pro 3.31.1
Post by CVH » Mon May 10, 2021 4:15 pm
Thanks, Pete
:shock: Bummer, clearly mine are not. :cry:
Thanks for trying out,
Post by CVH » Mon May 10, 2021 4:24 pm
And what about lineweights and very bold text.
015 is rather common on A3 .... Confused.
Text is hardly readable.
pdf included.
DimTextColorPersistent.pdf
(11.09 KiB) Downloaded 922 times
petevick
Post by petevick » Mon May 10, 2021 4:35 pm
pdf included.
That is weird. All I can see is that layer 0 lineweight is 0.25mm, with your dim text being white is it possible that the text is on layer 0 :shock:
Pete Vickerstaff
petevick
.....but that's not possible !!
Pete Vickerstaff
Post by CVH » Mon May 10, 2021 5:10 pm
Correct, dim text can't be on a different layer.
Nor that changing layer0 weight has any influence.
Nor any other layer its weight.
Nor layer0 compatibility.
Thanks for thinking out loud,
Husky
Moderator/Drawing Help/Testing
Post by Husky » Mon May 10, 2021 9:47 pm
Work smart, not hard: QCad Pro
QcadPro, QcadCam, Win11/64, 64GB RAM, 10-Core, SSD
If a thread is considered as "solved" pls. change the title of the 1. post to "[solved] Title..."
Post by CVH » Tue May 11, 2021 1:51 am
Thanks Husky,
There was nothing mentioned about dim text colors, so I disregarded that bug report.
Render text as text is my default.
Even my oldest file uses font 'Standard' & byLayer.
Seems I have tons of files to update to what is called 'default'.
Will be busy for a while :lol:
Post by CVH » Tue May 11, 2021 2:18 am
All,
Seems that the default CXF standard font must be replaced by a TTF font.
Anyone an idea for a good line art font in TTF?
Can't come up with any as TTF are pockets.
Nigel
Junior Member
Post by Nigel » Tue May 11, 2021 2:55 am
An ignorant reply coming up!
I use TTF "Arial" which is very popular I understand and sort of a standard. Arial is useful with a word processor as well (and may import text) from a typed schedule or say a specification.
On the same subject (I think?) Does it show up in Property Editor? It does come up as Arial if you insert as a Custom Property.
Post by CVH » Tue May 11, 2021 5:29 am
Hi Nigel,
In the firm I worked for, the standard was a basic and legible line-art font similar to Standard.cxf
That originated from lettering guides as ISO3098/1-DIN6776
"Back in the drawing board pen and pencil/ stencil days the international standard was for an IS font with an open 6 and 9, open 4, serif’d one, and barred seven."
Since CAD ...
Seems that ASME Y14.5M is the ANSI/ASME standard.
While most of the world is changing over to Arial.
"Arial seems to be the default for Revit – and while this used to crash pen plotters, and cause screen flickering when zoomed in (due to the font’s sharp edges), it’s no bother these days – it just uses a lot of ink and is a bit on the thick side when drawings are busy."
So, I am not alone when saying that Arial isn't best suited for thechincal drawings.
petevick
Post by petevick » Tue May 11, 2021 6:59 am
Just to be different, I use Liberation Sans Narrow, don't know if that's available in Windows though.
Pete Vickerstaff
Post by CVH » Tue May 11, 2021 8:59 am
Thanks, Pete
Liberation Sans Narrow ~= Arial Narrow
Took a while but it seems that I had the ISO TTF's at hand stowed away somewhere.
As engraver I have far to many fonts to all be installed under windows. I use a font manager.
ISOCP = QCAD Standard CXF = single stroke TTF :shock: and has the same issues as Standard CXF
ISOCPEUR ~= QCAD Standard CXF = normal TTF :)
Snippet from: https://en.wikipedia.org/wiki/Engineering_drawing
When CAD drawings became more popular, especially using US American software, such as AutoCAD, the nearest font to this ISO standard font was Romantic Simplex (RomanS) - a proprietary shx font) with a manually adjusted width factor (over ride) to make it look as near to the ISO lettering for the drawing board.
However, with the closed four, and arced six and nine, romans.shx typeface could be difficult to read in reductions.
In more recent revisions of software packages, the TrueType font
ISOCPEUR reliably reproduces the original drawing board lettering stencil style,
however, many drawings have switched to the ubiquitous Arial.ttf.
ISOCPEUR is a TTF and it is ISO ... Now everyone is happy.
Regards.
petevick
Post by petevick » Tue May 11, 2021 9:04 am
good grief, I remember RomanS in Autocad, a really awful font, even way back 40 some years e_surprised
Pete Vickerstaff
Return to “QCAD 'How Do I' Questions”
