Screen Cursor Size
If you are having problems with QCAD, post here. Please report bugs through our Bug Tracker instead.
Always attach your original DXF or DWG file and mentions your QCAD version and the platform you are on.
colpat47
Newbie Member
Screen Cursor Size
Post by colpat47 » Tue Oct 28, 2025 7:45 am
Hi,
I have just upgraded my operating system from POP_OS 22.04 to POP_OS 24.04 LTS Cosmic
Since re-installing QCAD I cannot get the cursor to the right size - if I got outside the QCAD display the cursor drops to the right size.
My external screen is 23.4" @ 1920 x 1080, 60Hz & scale 100%.
I have screen pics of cursor. In QCAD quite large, move onto open app and cursor drops to proper size.
Does anyone know how to change the cursor size? I have looked in App Preferences - Graphics View - Appearance but can't find anything to change.
Cursor Small Other App..jpg (829.98 KiB) Viewed 4291 times
Cursor Large in QCAD.jpg (837.01 KiB) Viewed 4291 times
andrew
Site Admin
Re: Screen Cursor Size
Post by andrew » Tue Oct 28, 2025 7:50 am
colpat47
Newbie Member
Post by colpat47 » Tue Oct 28, 2025 10:03 pm
Recommended link option does not work. I have it set to system cursor.
Cursor Small.jpg (252.63 KiB) Viewed 4235 times
Cursor Large.jpg (232.63 KiB) Viewed 4235 times
andrew
Site Admin
Post by andrew » Wed Oct 29, 2025 8:18 am
Thanks for the feedback. Unfortunately, this means we cannot solve this problem from our end as this would be a system setting, feature or problem as the window system is controlling the cursor size.
Can you please indicate your exact QCAD version and if you are using Wayland or X11?
colpat47
Newbie Member
Post by colpat47 » Thu Oct 30, 2025 2:43 am
Please see attached screen shot
andrew
Site Admin
Post by andrew » Thu Oct 30, 2025 8:05 am
If you are willing to invest some time in resolving the issue, you might want to try the 3.32.3.1 development snapshot release which is Qt 6 based. You can download it from your download link under "QCAD Professional Snapshots".
If that does not solve the issue, try to change "-platform xcb" to "-platform wayland" in the "qcad" launch script. That might make a difference as well.
colpat47
Newbie Member
Post by colpat47 » Thu Oct 30, 2025 9:06 am
Many, many thanks Andrew, I will try your suggestions and let you know.
colpat47
Newbie Member
Post by colpat47 » Fri Oct 31, 2025 1:56 am
I downloaded and installed 3.32.3.1 but couldn't get it to open by double clicking on the desktop icon. I changed -platform xcb to platform wayland in the qcad file but it still wouldn't open.
I tried changing the platform xcb to platform wayland in the qcad file for version 3.32.4.0. But by doing that, that version then wouldn't work either. Changed the platform back to wayland and system still wouldn't work. Had to delete system and re-install.
Do you think it would have anything to do with the new Cosmic desktop environment?
andrew
Site Admin
Post by andrew » Fri Oct 31, 2025 8:26 am
Unfortunately, it could have anything to do with Qt, your window manager, Wayland, your external monitor, Cosmic or any combination of any of those.
Disconnecting the external monitor seems like an easy way to confirm or rule out the monitor as a potential cause, assuming that you are on a laptop with an external monitor attached.
Also: did you try to disable system mouse cursors and use the Qt mouse cursors instead?
colpat47
Newbie Member
Post by colpat47 » Fri Oct 31, 2025 9:57 pm
Have tried on laptop with same results.
How do you disable system mouse cursor and use Qt mouse cursor?
Return to “QCAD Troubleshooting and Problems”
