Hello!
I can not to a search for Library Elements with Umlauts. Would be great, if that woudl be possible.
greets
ikua
						Search in Library Browser for Umlauts
				ikua
 - Full Member
 - Premier Member
Re: Search in Library Browser for Umlauts
Perhaps this is the issue:
Opening Files with umlauts under Linux
However, I searched and it seems that you are using Win10
				ikua
 - Full Member
Yes using Win 10
Version:
3.30.1.0 (3.30.1)
Internet:
QCAD.org
Erstellungsdatum:
Jun 18 2024
Revision:
5067327
Qt Version:
5.13.2
Architektur:
x86_64
Compiler:
MSVC++ 14.0 (2015)
Should it work? I tried to switch to german Language in qcad, but did not change anything.
						Version:
3.30.1.0 (3.30.1)
Internet:
QCAD.org
Erstellungsdatum:
Jun 18 2024
Revision:
5067327
Qt Version:
5.13.2
Architektur:
x86_64
Compiler:
MSVC++ 14.0 (2015)
				ikua
 - Full Member
it seems also, that the search engine treats the umlaut as normal vocal. Searching for "flü" lead to results witch contain "flu"
						- andrew
 - Site Admin
