Updating Icons problem
Do you have a question you want to ask an existing QCAD user about QCAD and what you can do with it? Do you want to know if a particular feature exists? This is the place to ask.
Petulinek
Registered Member
Post by Petulinek » Fri Oct 24, 2025 8:29 am
after installing QCAD, the "Updating Icons" update started and got stuck (it wouldn't finish even after 15 minutes). After forcequit and restarting, the situation repeats. The same after reinstalling. MacBook M1 Pro, Sequoia 15.7.1
andrew
Site Admin
Re: Updating Icons problem
Post by andrew » Fri Oct 24, 2025 8:47 am
Thank you for trying QCAD.
Please follow this tutorial:
Resetting the QCAD Configuration
https://qcad.org/en/tutorial-resetting- ... figuration
The problem only affects the trial version.
Return to “Pre-sales Questions”
